Sticking clutch
Freddie
01-19-2002 14:26:23
Need help! After my TO-30 sat for 6 months, it surprisingly started right up. Then I found out I couldn't shift. It is acting like I am not depressing the clutch pedal when shifting. Do I (gulp) have to split the tractor to work on the clutch? Tips?
It ran fine before I parked it.
Fr
gatractorman
01-21-2002 15:47:52
 Re: Sticking clutch in reply to Freddie, 01-19-2002 14:26:23
Hey Freddie mabye we need to know a little more info about what it is doing, is the tractor stuck in a gear and wont come out or does it seem like the clutch pedal is not pushing the throw-out bearing or does the clutch pedal feel like it always has and you just cant get it in any gear while its running without scraping?????
Freddie
01-21-2002 21:32:18
 Re: Re: Sticking clutch in reply to gatractorman, 01-21-2002 15:47:52
I start the TO-30 by using the gear lever. Once engine is running and clutch pedal depressed, I can't shift into any gears because I can hear and feel the transmission gears grinding. Clutch pedal has tension on it, meaning pressure plate is fine. We jump started the tractor on 4th gear and I pretty much rode on the clutch pedal and brakes hoping for clutch slippage. No luck.
Mike
01-21-2002 00:54:19
If it will shift when the engine is not running,then start it in gear and horse the throttle back and forth. If it won't shift, it can usually be freed up by prying the gear through the oil fill. You should see Big Deans web sight. Good Luck: Mike
steve
01-20-2002 18:10:57
when mine sticks i just put it in high gear hold clutch in by hand and rock it back and fourth hard
gatractorman
01-20-2002 04:06:24
Hey Freddie, try this if it's just the clutch disc stuck to the flywheel this should work, put some kind of ground engaging implement on it (plow, etc.) select the highest gear possible that it will still pull the implement in and start the tractor in that gear (be careful) then go to work and all the while have the clutch pedal pushed in (disengaged) the theory is the resistance to move the tractor by the implement being in the ground and the engine still trying to move the tractor will create slippage somewhere (hence the higher gear so the tires wont do the slipping) and since the clutch pedal is pushed in the only place it can slip is the clutch disc. Good Luck
smokey
01-21-2002 01:55:19
 Re: Re: Sticking clutch in reply to gatractorman, 01-20-2002 04:06:24
I would be a little careful cause if it don't give and the tyres don't slip you are gunnar flip one tractor.
gatractorman
01-21-2002 02:50:04
 Re: Re: Re: Sticking clutch in reply to smokey, 01-21-2002 01:55:19
Hey Smokey, I highly doubt its gonna hook up that good, if nothing dont slip it will choke the engine since he's in a higher gear.
Ray
01-21-2002 07:51:15
 Re: Re: Re: Re: Sticking clutch in reply to gatractorman, 01-21-2002 02:50:04
The first thing that I would check is your freeplay on your cluth pedal. My TEA 20 sticks around the sleeve where the shaft enters the clutch housing. When it does that, I remove the clutch petal, spray it with WD40 on both sides of housing and work the shaft loose, reinstall petal and set set my throwout clearance and carry on.
Putting an implement into the ground can`t help if your petal has slipped on the shaft.
Ray
ralph
01-21-2002 16:11:58
 Re: Re: Re: Re: Re: Sticking clutch in reply to Ray, 01-21-2002 07:51:15
You hit the nail on the head. My uncle had a MF165 that he claim that the clutch was out. He was trying to sell the tractor for that reason. After getting no offers, I made him one in hopes of him selling it to me. He knew that I was up to something. After a couple of days, he called and ask what I would charge to correct the problem. His clutch shaft had rusted and the clutch petal slipped. A 99 cent can of WD40 was all he needed and adjusted the clutch.
Freddie
01-21-2002 21:32:42
 Re: Re: Re: Re: Re: Re: Sticking clutch in reply to ralph, 01-21-2002 16:11:58
My clutch pedal springs back when I lift my foot off. Wish the problem with my tractor is just tha
Freddie
01-24-2002 23:33:36
 Re: Re: Re: Re: Re: Re: Re: Sticking clutch in reply to Freddie, 01-21-2002 21:32:42
Just to let you know that I ended up splitting the tractor in half to get to the clutch. Sure enough, the clutch disc was sticking to the flywheel. With a trusty old screw driver, it came off easy.
I want to thank all who responded to my call for help. You guys are great!
Fr
gatractorman
01-20-2002 09:53:34
Oh BTW I'm sure this theory is someones law of physics just dunno who it was he's a fart smeller tho eeeerrrr....I mean smart feller.
Wilber
01-19-2002 23:29:54
Happened to my TO-35. Got real concerned when she wouldnt shift. Acted like it was jammed. After I ruled out a few suspecions, and had the oil filler cap off I was able to use a small prybar to slide (one notch back)the first rod exposed. Sorry I cant think of the name of that bar/rod in the tranny. My parts book in out in the tool shed. But once I clicked it back a notch, all was fine in the world. Wont worry about that again. Good Luck.
