Hydraulics won't lift weight(grader)...
JMKinMich
01-16-2002 09:29:08
I just bought a MF135 with front loader and grader-box. (extra heavy to balance loader. Worked fine initially (3 months ago) now when attempting to lift the grader it stops once it gets to the bulk of the weight. Many people suggested to let it warm up but no difference. I've got the parts manual and medium repair experience but just not with tractors/hydraulics. Hoping someone can tell me briefly where to start. (first few things to check/clean/change)Thanks.. Joe
skeeter
01-17-2002 16:17:53
 Re: Hydraulics won't lift weight(grader)... in reply to JMKinMich, 01-16-2002 09:29:08
I had the same problem.My fluid in my MF135 was watery,so i changed it using sae 90 what the book called for. Then it whould only lift untill it got the weght on it.So i changed it again using hydraulic fluid,Now it works like new. good luck
Gary
01-16-2002 14:42:53
Joe,
Check hyd. fluid for water(fluid will be milky). Second, filter may be plugged.
Gary
