Loose Control Levers on Loader
Davis D
01-16-2002 08:30:01
The loader control levers are very loose. It looks like the pivot holes has worn so much that they wobble and rest next to each other when not in use. How can these levers be removed and are there replacements available. 1968 "MF 40"
Thanks for any help or ideas.
Tim
01-16-2002 13:51:03
 Re: Loose Control Levers on Loader in reply to Davis D, 01-16-2002 08:30:01
If you are talking about the levers on the spool hdy. valve, the ones that make it go up and down etc. I had the same problem. You can take it apart and knock out the guide bushings and replace the levers or as I did knock out the bushings and put small washers on both sides of the levers to take up the side to side slack, reinstall the bushings and mine worked good as new. Good luck.
