MF 97
Jim Klopfenstei
01-14-2002 06:14:33
Some one tell me the difference in the 95's and 97's.
Ray
01-21-2002 08:09:27
 Re: MF 97 in reply to Jim Klopfenstein, 01-14-2002 06:14:33
Nobody mentioned the biggest difference if you are going to use one is that the MF 95 has NO live PTO.
JK
01-15-2002 06:24:17
Jim,
Roger is correct except that the 97 is either a G705 or G706 M-M which both have the 504 CuIn engine. The G704 had the 425 engine & was the 4wd version of the GVI.
John
Roger A. NY
01-14-2002 16:05:09
Jim,
First of all a MF 95 is a MM GB, a 95 Super is a MM G VI and a 97 is a MM 704 or 705, depending on whether or not it has front wheel assist. The biggest difference between the 95 and 97 is the 95 has a 425 cubic inch eng. while the 97 has a 504 cubic inch engine. There are quite few other differences such as the injector pumps. If you need more you might check with the MM board.
Hope I helped some. Roger
