TO30 Oil line
Dennis
11-02-1998 09:50:46
When I got my TO30, the oil pressure gauge was disconnected and a line was run from the side of the block to a fitting in the back of the head presumably to supply oil to the valve train. I see no mention of this in the shop manual. It says the oil gauge is fed from the fitting in the side of the block. If I put a tee in the line and feed the gauge, won't the pressure reading be off as the oil finds its way to the head ?? I've just overhaulerd the engine and am in the process of re-installing it and wonder if the valve train oiler is needed. Any answers would be appreciated. Thanks.
Gerald
11-02-1998 20:40:46
 Re: TO30 Oil line in reply to Dennis, 11-02-1998 09:50:46
: When I got my TO30, the oil pressure gauge was disconnected and a line was run from the side of the block to a fitting in the back of the head presumably to supply oil to the valve train. I see no mention of this in the shop manual. It says the oil gauge is fed from the fitting in the side of the block. If I put a tee in the line and feed the gauge, won't the pressure reading be off as the oil finds its way to the head ?? I've just overhaulerd the engine and am in the process of re-installing it and wonder if the valve train oiler is needed. Any answers would be appreciated. Thanks.
The Continental engine is bad about loosing oil to the rocker arm shaft. I think the problem is the corks in the end rot out, then the oil pressure at the rocker arms falls and they drag and break off the pin that keeps the rocker arm shaft from rotation. Once that pin is broken the shaft rotates in the towers and shuts off the oil passage in the end tower from below. And then things get worse. If in your rebuild you have cleaned out the passages so that there is oil to the rocker arm shaft for sure and that the ends of the shaft are plugged (I just made a new shaft that uses 7/16-20 set screws for plugs) then the pipe outside shouldn't be needed. There's an extra hole in the rocker cover probably from it. But the thing to make sure of is that there's oil from the internal passage. It may need roto rootering with wire and brushes to make oil rise to the rockers.
It could be that deposits from using non detergent oil has blocked the oil passages, then the other stuff happens later. Some of the early ford ('58+) overhead car engines had the passage clogging problem. It was in their lower cost engines for compacts, not their first overhead valve engines. At least not in my experience.
Gerald
