Constant pumping ,Lift height on MF175
Shock
01-07-2002 14:38:12
I just done some hydraulic work on my 175 and would like to know if it is working right.When I move my position lever to the stop it does not lift all the way up I have to go past the stop into constant pumping to reach maxiumn height.Is this the way yours does?
Big Dean
01-07-2002 20:36:54
 Re: Constant pumping ,Lift height on MF175 in reply to Shock, 01-07-2002 14:38:12
Put the position lever in constant pump. Make a scribe mark across the liftcover & upper Lift arm. When you put the Position lever in transport the mark on the cover & the lift arm should separate 1/8" If I can help you email me
Shock
01-08-2002 03:37:01
 Re: Re: Constant pumping ,Lift height on MF175 in reply to Big Dean, 01-07-2002 20:36:54
Thanks Big Dean for the response can I leave the position lever in constant pumping (at all times) and use the draft lever to raise and lower my lift?
Big Dean
01-08-2002 09:59:40
 Re: Re: Re: Constant pumping ,Lift height on MF175 in reply to Shock, 01-08-2002 03:37:01
As long as it is not blowing the relief valve yes. You don't want to drive it with the relief Valve blowing.
