: Hi Jim - : We replace them when the pin shows appreciable wear - 1/16" or more. Bushings usually are worn more. They can be replaced separately. When we do, I use 2 bushings - one on each side of the axle, and drill the axle for a 90 deg. grease fitting, so the grease gets into the center of the cavity between the 2 bushings. : Stops the squeak, and I think lengthens the life. Probably that's academic, because they are 40 years old now, and if greasing doubles the life of the replacements, we (our successors) will probably be out of fuel to run the tractors!!!! : The ball joints on the rear of the radius rods can be tightened by filing a bit off the mating surface on the retaining caps. I pack them with grease before reinstallation. : BTW, the pivot pins are about $31 US and the bushings about $6 US each here in Canada. : Jack Seems weird to me but the Ferguson Shop manual says DO NOT grease the pivot pin because the grease will pick up dirt and shorten the life. It does say that graphite is OK. Sounds like they expected it to wear out.
