Help, MF50 alternator drive belt
Tony S
01-06-2002 03:32:03
Can anyone tell me how to change the alternator drive belt on an MF50 Loader/Backhoe? Clearly the belt goes around the crankshaft pulley. On this machine there's a shaft from this pulley to the hydraulic pump. I can disconnect this shaft (four bolts), but it appears only to rotate, not move clear of the pulley to let me get the belt around.
I can't believe the hydraulic pump has to come off to change this belt - removing the pump looks quite a major job.
It's a British MF50B, around 1975.
Thanks in advance, Tony S
michael dipierro
02-09-2005 18:20:27
 Re: Help, MF50 alternator drive belt in reply to Tony S, 01-06-2002 03:32:03
Hi i own a 1971 mf 50 i just did a water pump belt etc. you have to remove the 4 bolts on the crank pulley,take off the front screen on the machine. The only way to split the shaft is to remove the 2 hydraulic pump bolts.them the pump and shaft will move forward.
Tony S
01-07-2002 00:14:25
Done it! It first looked as if I couldn't access the pump fixing bolts without taking all the hose fittings off. Following your comments here, I had another go and the pump can be _just_ moved enough to squeeze a belt through.
Thanks again, Tony.
Jack Fowler
01-06-2002 05:31:36
Tony, the hydraulic pump shaft will move forward enough to remove and replace belt. It will be tight. Sometimes you may have to tap pump shaft to get it moving. If I can find it in the service manual I'll scan it and mail it to you. Jack
Tim
01-06-2002 19:56:41
 Re: Re: Help, MF50 alternator drive belt in reply to Jack Fowler, 01-06-2002 05:31:36
Tony I have a MF 40 Industrial yr 75 and have the same setup, if you are lucky enough to move the shaft forward ( I could not ) and replace the belt put a second belt on first out of the way so if it happens again you are set. If you have to remove the pump just take the 2 bolts out with a crows foot and move it forward. Good luck Tim.
