MF 65 Diesel External Hydraulic Connections
Tim Scull
01-03-2002 06:33:44
I just bought a 1960 MF65 diesel and I need help in determining where to connect external hydraulic lines. I want to use the internal hydraulic pump to drive the pistons on a 4-way snow plow (which I have just finished mounting). I can see where to attach the high pressure line. My problem is where to attach the low pressure return line. My best guess is to use the large diameter fill plug next to the shifters by drilling the center out and tapping it for a pipe fitting. I expect this will work but it is a bit of effort and rather inconveniently located. I'm guessing there is an existing plug I can thread into. Please help. Thanks.
Tim
Peter Tatham
01-05-2002 02:18:13
 Re: MF 65 Diesel External Hydraulic Connections in reply to Tim Scull, 01-03-2002 06:33:44
Tim, I have a 65 Mk1 which has been modified as you suggest. It works perfectly.
Regards,
Pete.
