Z134 main lock wire??
Evan MacDonald
01-03-2002 05:15:10
Is the main bolt lock wire absolutley necessary? My reason for asking is that the hole in one of the bolts on the rear main is pointing right into the steel, and I haven't been able to get any kind of wire through it? Should I over torque that sucker so I can get the wire through, or, will it be OK?
Evan
Bob in CA
01-04-2002 08:13:09
 Re: Z134 main lock wire?? in reply to Evan MacDonald, 01-03-2002 05:15:10
I would try to remove the bolt and swap it with another to get the holes in an acceptable position. I would not overtorque. I don't believe that the wire is essential. Most engines do without. Safety or secutity wire does not keep a fastener tight. It merely keeps the fastener from loosening further. Friction is what keeps the fastener tight and if you tighten or torque the fastener properly, it will not come out. The bottom line is that if the bolt were to loosen, The bearing cap would start working it's way loose anyway eventually ruining and spinning the bearing. A little loose is all it takes. IMHO>In my humble opinion. For what it's worth> FWIW
