: What is the proper procedure for using Multi-power? Do I understand correctly you ONLY "shift" multi-power lever while in motion and never idle? What damage would happen shifting at a dead stop or is an old wive's tale? I'm looking at a MF175 with Multi-power that I may buy. Somewhat more fancier than my MF135 (but she's Miss Reliable!!) I shift multi-power any time. Stopped and out of gear is the best time, because the transmission is easier to shift in low range. I high range the multipower acts as a "hill holder" ala Studebaker cars. e.g. it holds the tractor, but that puts pressure on the transmission gears making it very hard or impossible to shift out of gear. M-P is a large version of a Sturmey-Archer planetary bicycle transmission. Its got to be toughest on it to shift with full throttle and full load (e.g. plowing when encountering tough dirt), but that's when its needed and what its made for, I believe. There are no restrictions mentioned in the MF-135 owner's manuals that I have. I definitely can hear the ratchet palls catch with a click. On the other hand, I hear that parts are nearly impossible to buy, and that makes fixing M-P more than a little difficult. On my MF-135 I seem to have a control valve leak that adds oil to the clutch bell housing when in high range. But I keep using it. Its so handy splitting speeds to 12 gears forward to match the ground speed to the work in progress while keeping up the PTO speed. Gerald
