135 MF
Chuck
01-01-2002 18:34:33
Had the hydraulics worked on a few months back, all worked well. Now, I can be bushhoging and for no apparent reason(as if hydraulic has mind of its on) hydraulic will raise bushhog up. All help appreciated.
Tyler(WA)
01-02-2002 08:35:01
 Re: 135 MF in reply to Chuck, 01-01-2002 18:34:33
Along with Tim's good idea... make sure your response control isn't walking over to slow. Mine does and sometimes acts that way. Switching it back to fast seems to work.
Tim
01-01-2002 20:36:45
Chuck, I have a 1975 MF 40 Industrial which is the brother to the 135 AG. I had the same problem and what I discovered after the dealer said oh yea bring it in ( for who knows how much $$$$ ) was that my position lever was inching up as I drove and to fix it all I had to do was tighten the tension spring on the lever so it would not come back past the stop when it was set. At least that solved my problem, good luck. Tim
