Steven
01-07-2002 06:34:44
Re: Re: MF 90 ? Hydraulic Problem? in reply to winston, 01-05-2002 07:19:33
Thanks for the help, I did go yesterday, (because it had warmed up) and looked into the problem some more. I started the tractor up, and checked the power steering, it worked, so I then checked the 3 point, that worked, and finally I put it into gear, and that worked, so at least the pump is working. I checked the fluid, and without changing it (I didn't have any on me yesterday) It did have some water in it. I didn't change the fluid as of yet, because the location of the tractor now is about 1 hour from my house, and it started getting cold and snowy. Is there any good way to circulate new oil arround to get any water that might be in the lines out? Do you know commonly where they leak the water in from. The tractor has sat indoors the majority of the time that I owned it, only recently (past 3 weeks) has it sat outdoors, and it was covered very well (4 tarps, and alot of bungies), so I'm not sure where it is coming in. The only place that I can visibly see that it could be getting in is around the shifter, the boot is ripped, but it hasn't been out in the rain, so I'm not sure. Any help is greatly appreciated. Thanks again.
