Looking at a 255, give advice.
craig
12-27-2001 17:43:52
I'm thinking of trading in my MH-50 on a MF-255, the dealer said that it was 52 PTO HP. It has 1 set of aux. outputs, rear tires are very good, front tires are doable. No apparant oil leaks, paint is alittle weak, has multi-power, but I'm not sure that it works. It has flexable lower link ends, and all the gauges seems to work, except the tach. and is says 3203 hours. I couldn't get the lift lever to come out of the cont. pump location, I pulled right good on it but it didn't budge. Could that be a problem? The PTO shifted in and out with no problem, it started up cold in about 35-40% weather, though the starter missed the first and second time I hit the switch. Engine oil looked ok and so did the transmition. Asking price is $4995. All comments welcome.
Thanks in advance,
Craig
