Solution for 2757600M91 boom pivot (discontinued by MF)
J. Pratt
10-29-1998 12:03:32
Boom pivot casting part#: 3500057M7 will work.
The only diffrence in the two castings is the hole size
in the tip; where the boom cylinder pin goes through.
The old pivot casting takes a 1 1/2" x 5 9/16" pin. The
new pivot casting takes a 1 3/4" x 10 1/2" pin.
To adapt the new casting bushings (2) are needed
(1 1/2"x1 3/4"x1 1/2" long) and a new pin 1 1/2" x 10 1/2"
with a 10mm hole drilled 2" from one end for the lock.
If this helps anybody... Please feel free to let me know.
