Massy 30
troy
12-25-2001 15:24:02
Where is the throttle lever located on a 1948 massy 30 is it on the sterring post or bettwen your legs
BlueLite
12-29-2001 14:54:00
 Re: massy 30 in reply to troy, 12-25-2001 15:24:02
My 51 is mounted on the steering post an the quadrant is arranged in a front back position.
forward/back to throttle.
My 47 is mounted the same cept the quadrant
faces you. left/right to throttle.
The throttle is meant to facilitate 2 modes
and to get into another mode you have to pull the throttle lever out (spring loaded) to bypass the step on the throttle. The other mode is for
continuous run to operate stationary machinery.
Tom
12-26-2001 16:16:41
My 1948 Massey Harris 30 is right under the steering wheel on the post. It has a special throttle linkage that is a one piece system all the way to the govoner. The mount on the pan is different as well. If you get the throttle under the steering wheel, make sure you get the whole thing. My 30 is the only 30 that I have seen under the steering wheel. The 1949 Massey Harris 30 has the throttle down below. I know this because I own a 1948, 1949, and a 1950 Massey Harris 30. The grille should not have a hole in the top for the hydraulic resinor. There should also be a flat cast plate where the hydraulic pump should be.
