Adding Remote Hydraulics to MF 245
Ron Tiemann
12-17-2001 17:07:14
I'm considering adding remote hydraulics to my MF 245 Diesel and am having a heck of a time finding a place to mount the spool (control valve). I have a 2 spool Gresen valve that I would like to use. Taking a quick look at my owner's manual, I noticed a photo of a remote valve mounted between the seat and left fender over the axle. This location makes sense because I believe the tap into the hydraulic system is on the left side of the tractor as well. When I approached my local Massey dealer regarding ordering the special bracket for mounting the valve, they looked at my like I was nuts...they couldn't find anything in the parts book either.
I would appreciate some pointers or suggestions from anyone who has already done this, or a source to the correct parts for the addition.
ralph
12-18-2001 15:05:59
 Re: Adding Remote Hydraulics to MF 245 in reply to Ron Tiemann, 12-17-2001 17:07:14
The owner's manual shows the mounting bracket for the auxiliary hydraulic system. Several 245's have the auxiliary system which is a seperate system from the main hydraulic system. They were offered in single spool (2 remotes) or two spool (4 remotes). I have owned a 245 orchard model for several years, have the two spool auxiliary hydraulic system. This unit has the canister type hydraulic filter and hydraulic oil cooler. I have seen some 245's for sale in the past couple of years where the auxiliary hydraulic system had been removed. I was told by a tractor dealer that the units were removed and installed installed on newer tractors. What was so interesting about the removal, he didn't lower the sales price of the 245.
charles
12-17-2001 18:12:12
i have a model 245. the hydraulics are connected to the tractor on top of the transmission between the seat and shift lever. the mf dealers has a kit for this. if you ask the parts man he will give you a printout from his computer that shows how everything is put together. i got my external or remote setup from a tractor salvage place. the are several models that inter change. hope you get it going.
Ron Tiemann
12-18-2001 06:51:28
 Re: Re: Adding Remote Hydraulics to MF 245 in reply to charles, 12-17-2001 18:12:12
Thanks, seems like I remember a similar setup on an uncles 135 years ago. Looks like I need to find a better parts man....
I looked at that location for a while, but gave up on it because it seemed like my floating seat would hit the spool. Sounds like another visit to the dealer is in order.
