: I purchased a TO 30 to grade my property, and discovered it will not "float" it only will work all the way up or all the way down. IS THERE A FIX???? Thanks a million, David C David, I too have a TO-30 with a grader blade, and know exactly what you're talking about. There really isn't a way that I know of to make the hydraulics float; about the best I can do is have it slowly creeping up or slowly creeping down. However, you can set how far down the lift travels with the use of limit chains. CT Farm sells these, or they're fairly easy to make if you've got a welder and are handy with metal fabrication. Basically, limit chains connect to the top link attachment point on your tractor, and connect to the lower attachment point on the implement you're using -- bush hog, grader box, whatever. You adjust the chains to limit the lift's downward travel. Do a search for "limit chains" on the N-Board at this web site, you'll find some very nicely drawn prints on how to make your own limit chain set. It isn't a perfect solution, since the grader box or blade can't "float" downward beyond the limits of the chains, but it beats spending all your time worrying where the lift is when you need to concentrate on driving! Good luck! Jim
