MF 40 Industrial Aux. pump problems
Tim
12-09-2001 19:55:08
I have a 75 MF 40 W/34 loader, today the pump I think started making noise like a berring was out or something I cked the hydro fluid level and it was a milky white and low so I added some standard hydro fluid. The next thing I know is the noise got louder and I had no power to my loader or box scraper which are hooked to what I guess is an aux pump on the front of the tractor, any thoughts as to what is wrong ? Thanks Tim.
rob
12-15-2001 10:42:12
 Re: MF 40 Industrial Aux. pump problems in reply to Tim, 12-09-2001 19:55:08
Hi Tim
your milky white hyd oil could due to water in the systerm all so a blocked hyd filter will make the pump noise it should be changed every 200hrs as it is in the supply side of the system all so check the supply hose from filter to pump for leaks it should have 2 hose clips on each end. it can pull air in to the system through this hose and make the pump noisey (cavertion) good luck rob
