MF1085 starter
Wolf
12-09-2001 05:05:00
everything yesterday was fine, no previous starter problems, went to start the 1085 again, solenoid just clicked. simple cleaning of the starter going to suffice???? I hope.....
rhudson
12-11-2001 13:34:37
 Re: MF1085 starter in reply to Wolf, 12-09-2001 05:05:00
starter solenoid on that starter does two functions, throws starter gear out to engage flywheel and then closes contacts to supply power to starter motor. got a new replacement at local rebuild shop for about $20.00, but the rebuild of the starter itself cost about $200. isn't that one bolt toward the motor block a pain to get to?
Big Dean
12-09-2001 08:00:02
Wolf check the connection where the strap from the starter hooks to the solenoid they are real bad about loosing contact there & of course I am sure you know to check the buttery terminals. I have made several 100 mile service calls for these two thing.
Wolf
12-09-2001 17:00:48
 Re: Re: MF1085 starter in reply to Big Dean, 12-09-2001 08:00:02
Thanks Dean. Also, the gear is not spinning out on the shaft like I assume it should. took the starter out tonight, hooked the cables to it, gear spins, but doesn't go out to the end of the shaft. Judging by the wear pattern on the flywheel, I'd say this has been coming.....
