Question for Big Dean
Jim in Tenn
12-01-2001 04:14:53
I read what you posted about using WD40. I don't doubt what you are saying, but at the same time, I don't understand how spraying WD40 in a diesel engine could hurt it. Please explain.
ErnieD
12-01-2001 16:01:48
 Re: Question for Big Dean in reply to Jim in Tenn, 12-01-2001 04:14:53
I understand the older cans of wd40 used propane as the propellant gas. New cans use CO2.
C. T. in Oklahoma
12-01-2001 14:29:03
My apologies to Big Dean for stepping in, but I believe the problem is the ignition point of WD40 as compared to diesel fuel. The WD40 (and gasoline from a rag, and starting fluid) ignites (called pre-ignition) while the piston is at a relatively low point in the cylinder and before the appropriate valve is ready to open, causing excessive compression which can damage the rings and even the piston. I hope others will comment and straighten me out if I am a little off base, but I am relying on my recollection of what my good neighbor told me.
C. T.
C. T. in Oklahoma
12-01-2001 14:28:44
C. T.
Big Dean
12-01-2001 07:29:53
I really don't know why it does it but I have been in to several Perkins engines that had sever blow by that started after using WD40. They always had ring grooves busted on at least one piston. I talked this over with our Massey Ferguson service rep. He could not tell me why so he call someone at Perkins. They told him that when it ignited it all ignited at once & just a little to much was more than the Pistons could stand. He also said if you had a way to meter it in it probably would not hurt the engine. These people may have went overboard with it I was not there to see. I do know it cost them a rebuild on their engines. Massey had a starting fluid injector you could get that meter the amount of starting fluid you used it worked. When I posted that it was just to warn every one of the danger of using it.
