Found more #s on 81
Ken K
10-25-1998 05:51:11
Found some numbers stamped in the top of trans just behind the shifter 425465 and a carb # of tsx34 and cast in the head is F140A 30 0 on the side of the engine under the oil filter is a tag with #s TR or TB 11219 Can any body help me with this please. Not having much luck finding info on this tractor locally. Thanks again. Ken.
Jack in NB
10-25-1998 13:08:51
 Re: Found more #s on 81 in reply to Ken K, 10-25-1998 05:51:11
Hi Ken -
The F140 number is consistent with the markings on a Continental F140 engine.
Hope this helps.
Ken K
10-25-1998 17:51:47
 Re: Re: Found more #s on 81 in reply to Jack in NB, 10-25-1998 13:08:51
: Hi Ken -
: The F140 number is consistent with the markings on a Continental F140 engine.
: Hope this helps.
Jack Thanks for the info. It looks like someone put a model 22 engine in this model 81. Bigger is better right! Book I have says it should be a 124ci engine. If I can find out what year it is maybe that would explain it.
Tom from Ontario
10-25-1998 19:00:41
 Re: Re: Re: Found more #s on 81 in reply to Ken K, 10-25-1998 17:51:47
: : Hi Ken -
: : The F140 number is consistent with the markings on a Continental F140 engine.
: : Hope this helps.
: Jack Thanks for the info. It looks like someone put a model 22 engine in this model 81. Bigger is better right! Book I have says it should be a 124ci engine. If I can find out what year it is maybe that would explain it.
:Ken. You might have one of the 81's that was sold originally to burn distillate. They got the 140 engine. Someone may have switched fuel tanks so it's just straight gas now instead of having two tanks. Is there a possibility you've got an 82? They were also equipped with the 140. Tom.
Ken K
10-26-1998 19:33:41
 Re: Re: Re: Re: Found more #s on 81 in reply to Tom from Ontario, 10-25-1998 19:00:41
: : : : Hi Ken -
: : : The F140 number is consistent with the markings on a Continental F140 engine.
: : : Hope this helps.
: : Jack Thanks for the info. It looks like someone put a model 22 engine in this model 81. Bigger is better right! Book I have says it should be a 124ci engine. If I can find out what year it is maybe that would explain it.
: :Ken. You might have one of the 81's that was sold originally to burn distillate. They got the 140 engine. Someone may have switched fuel tanks so it's just straight gas now instead of having two tanks. Is there a possibility you've got an 82? They were also equipped with the 140. Tom.
I found a web page last nite that has serial #s for antique tractors and it showed that in 1941 the #s started at 425001 to 425678 and this tractor has # 425465 stamped into the top of the transmission. Were there any other ways to tell if it was a distillete tractor? I wonder how many were made this way? They hide #s anywhere else? You guys are a big help. Thanks Ken.
Ken K
10-26-1998 19:33:39
: : : : Hi Ken -
