MF-135 (diesel) 3 point hitch lift
Don Simpson
11-25-2001 18:13:57
Lift won't pick up more than 150#. I checked hydraulics dip stick and found milky fluid. I changed fluid but this did not solve weak lift problem. Any suggestions? Thanks.
Jack in NB
11-27-2001 01:48:34
 Re: MF-135 (diesel) 3 point hitch lift in reply to Don Simpson, 11-25-2001 18:13:57
Hello Don -
Possible causes:
Plugged filter (accessible through the round cover on the left side by your heel - you'll have to drain a couple of gallons of oil, or put the left wheel up on an 8x8 and block the tractor from moving before opening to keep oil from running out.)
Blown o-rings in the pump or standpipe
Very tired pump.
There could be other causes, like ram piston /rings/cyl, but rare. You should have a shop manual before attempting work other than the filter cleaning.
There should be safety wire securing the screw-on cap over the filter - be sure to replace this before closing up.
