TO-35 Standard Diesel
Easier starting?
Trent
11-25-2001 14:46:19
Has anyone heard of a modification which can be done to the cylinder head on a 4 cylinder Standard
diesel to make it start easier.
The pre-combustion chamber is drilled with a 5/32"
drill straight down through the existing hole, which
is on about a 45 degree angle.
I am not sold on this idea but have been told that it works.
Has anyone else heard tell of this?
Jack in NB
11-27-2001 01:37:11
 Re: TO-35 Standard Diesel - Easier starting? in reply to Trent, 11-25-2001 14:46:19
Hello Trent -
I've heard of it, from an old MF dealer. I'm not sure how effective it was - ours was not fitted.
The best approach seems to be functioning intake manifold heater (or glow plugs on the later models) supplemented with a block heater or heater in the lower rad hose. Possibly the 300 watt magnetic block heaters would work as well. 15 minutes with the block heater in the summer, an hour or so in the winter, and it's away for the day.
Trent
11-27-2001 17:50:40
 Re: Re: TO-35 Standard Diesel - Easier starting? in reply to Jack in NB, 11-27-2001 01:37:11
Hi Jack,
Would the MF dealer have been a guy by the name of
"Red Richard" from somewhere in New Brunswick?
I noticed you signed "Jack from NB". I assume NB is New Brunswick.
Trent
PEI
