Lighting question
TomB
11-21-2001 19:43:47
2 parts: How much power will the DC system on my MF20D/Perkins diesel provide for auxillary use?
Searching catalogs for lights, I see a choice between trapezoidal, spot and flood patterns. Which would I use and why for a rear work light?
My thought is to put two on the back and two on the front to supplement the stock headlights.
Allan
11-23-2001 20:53:22
 Re: Lighting question in reply to TomB, 11-21-2001 19:43:47
I don't know how many lights those generators will run. You can do an amperage calculation if it is marked. Max is 80% of rated output and that would be pushing it. Regarding light patterns. The trapeziodal are good for headlights mounted on the tractor proper. Floods would be the ones for the back. Spots are for special things like pointing down the swath when baling. This is pretty basic but hope it helps.
