MF 184-4
Ralph Walton
11-19-2001 17:39:10
I'm looking at a MF 184-4 about 1978. It's pretty beat, and only 2 wheel drive at the moment. It has a blown front u-joint on one side, probably needs inner and outer shafts and the u-joint cage plus other bits & pieces. It has planetary front drive, and offset planetaries on the rear. Any feedback on this model? Any problems in running as a 2wd tractor?
Ralph
ronnie painter
02-18-2003 16:45:42
 Re: MF 184-4 in reply to Ralph Walton, 11-19-2001 17:39:10
you cant buy a better tractor than the 184-4 an i an give you all the info you want , have owned one since 1979. an would like to have another one or just the hood an fenders for one becouse my brother rolled mine over the hill an broke in three pieces an ran upside down for 5 minutes an put back togather an now it runs like a champ but needs fenders an a hood that i cant find.
Dave Donov.
11-20-2001 15:53:36
I think it is a Landini with AD4236 CID engine. Look for a manual pto clutch lever. It has an italian front wheel drive, not a Z-F.
Regards, Dave D.
HAMHOCKS
12-21-2001 07:46:48
 Re: Re: MF 184-4 in reply to Dave Donov., 11-20-2001 15:53:36
YOU ARE CORRECT THE 184-4 WAS MADE BY LANDINI, IF YOU FIND A LANDINI DEALER HIS PRICE FOR PARTS IS CHEAPER BY FAR THAN MASSEY,, AGCO HAS MARKED THEM UP AN IREDIBLE AMOUNT.
bill ny
11-20-2001 13:28:44
when i was just about done working for the massey dealer the 184-4 came out it was about the first small 4 wheel drive for massey the dealer sold 2 right off and were a good loader tractor from what i can remember sorry can't help more. usre would check on getting parts for the first off
randy
01-30-2002 15:29:21
 Re: Re: MF 184-4 in reply to bill ny, 11-20-2001 13:28:44
I've got one too. I screwed around chasing parts then had the local make almost everything I needed for peanuts.
Front u joint damage can be fixed with a little welding and machining. And I'm no machinist.
The yoke was a piece of sched 80 pipe with the shoulders cut as with the original. Drilled and Welded in washers for the cup retainers, cross referanced the u joints ($10-$20)at the local auto suply and had the steering pins made up on a lathe.($30 each.) A deburring tool and sized drill bits seem to set up the cup bosse just fine.
Its all held togethre for about 5 years now and I've never had the luxury of having breaks, some day.
I guess my only real conflict is with the bird brain that stashed the battery under the air cleaner, in front of the rad. If you have a good loader on this thing you could bust a nut yanking that old cow out of there.
Otherwise this is a sweet, small general purpose machine. Oh ya, CRAPPY ELECTRICS, Lucus.
Good luck.
