TO-35 oil pan removal
steve19438
11-18-2001 05:11:48
i posted this question on the ferguson page and have not received a response. what is the correct way to remove the oil pan from a Z-134 engine ? any tips suggestions will be greatly appreciated !!!!
B.C.
11-19-2001 12:39:28
 Re: TO-35 oil pan removal in reply to steve19438, 11-18-2001 05:11:48
When I took the pan off our MH50 it went kind of like this. First you should have something like an I&T Manual which will give you the broad strokes of this and a bunch else.
There's about a dozen bolts holding the pan. If I remember right it will help to loosen the larger bolts holding the front end on so as to let the pan come down more freely. Obviously you can overdo this part, so be careful.
Don't be surprised if you need to cut the old pan gasket loose with a putty knife and hammer.
Down she comes. You did drain the oil out of first, didn't you?
Have fun.
