Quieter Exhaust
Randy
11-14-2001 20:57:01
Folks: Does anyone know if a muffler from a small car would make my MF35 quieter. What car muffler would fit, it's a small pipe diameter? Would it kill the Z134's power, or make little or no difference? Thanks.
B.C.
11-20-2001 16:26:36
 Re: Quieter Exhaust in reply to Randy, 11-14-2001 20:57:01
I did pretty much what BlueLite suggests. When I got our MH50 it had a straight-thru on it and it was loud. Eventually it rotted out. I got a generic small-car muffler and it was a lot quieter and the power wasn't affected. Remember, even a wimpy car makes something like 60 or 70 hp, and the Z134 only goes about 32, with the same displacement (2.2 liters or so).
Where I used to work, a mechanic redid a mobile crane with a Ford 360 on it. He put a full-sized car muffler on it, and after that you had to watch out for the thing when it was being moved, it was so quiet.
BlueLite
11-16-2001 11:58:11
Always looking for the opportunity to try
one of those "thrush" mufflers on my tractor.
Heyyyyy, why not!!!!?? hee,hee. Go ahead and use one. Just make sure it's from a car with a slightly greater displacement than your engine. That's to ensure that the back pressure is not higher than the designed limit for your tractor. There are a lot of round ones available, but an off-center in out pipe might look kinda strange if it's the vertical stack type.
Blue.
Tyler(WA)
11-15-2001 08:21:27
If you have a vertical exhaust, try extending the pipe some. Just lifting the noise higher will sometimes make a big difference. Other than that, go to a good muffler shop with the pipe diameter and displacement of your engine. They should have some options for you.
I need to do the same for the same engine on my 2135. It has a low exhaust so I have less room to work with.
Jack in NB
11-16-2001 03:22:37
 Re: Re: Quieter Exhaust in reply to Tyler(WA), 11-15-2001 08:21:27
Hi folks -
The replacement horizontal muffler for the gas 35 and 135 are only about $20 US plus shipping, from aftermarket suppliers. Verticals are in the same ball bark price range.
