MF 200 DOZER TRACK
GARY WEIRICH
11-14-2001 12:15:38
I need two new or used track chain links cast(#FM-MF2) or comparable at 5-1/2 inches on pin hole centers. Any help, THANKS.
Deborah Davis
11-18-2001 18:54:45
 Re: MF 200 DOZER TRACK in reply to GARY WEIRICH, 11-14-2001 12:15:38
we have an MF200 also and need info on how to and where we can get parts and info on this dozer
GARY WEIRICH
11-18-2001 20:37:28
 Re: Re: MF 200 DOZER TRACK in reply to Deborah Davis, 11-18-2001 18:54:45
I AM BUYING THE DOZER IN WI TO RESTORE AND KNOW OF A PLACE TO GET PARTS IN MI, TRY C&J TRACTORS AT 810-397-2161, WHAT PARTS DO YOU NEED I MAY HAVE IT,OR KNOW WHERE ONE IS.
marlowe
11-14-2001 17:35:49
the name is david winkel ph. 1-920-622-3378 this is at wild rose wi.in centeral wi. good luck
GARY WEIRICH
11-15-2001 05:08:53
 Re: Re: MF 200 DOZER TRACK in reply to marlowe, 11-14-2001 17:35:49
Thanks, Marlowe I will let you know how it goes.
marlowe
11-14-2001 14:37:11
all i can tell you is that it has been sitting for three years in the woods don't know if it is tight or not it ran when parked it lost the oil out of the hyd. coupler on a scale of 1 to 10 it makes a 4 it is well worth it for the parts it is not mine i just came across it if you want the phone no. i will get it hope this helps
GARY WEIRICH
11-14-2001 16:21:39
 Re: Re: MF 200 DOZER TRACK in reply to marlowe, 11-14-2001 14:37:11
YES,Thanks Marlowe a phone # willbe a good start.
marlowe
11-14-2001 12:39:57
i know of a hole 200 for sale for 500.00 it's in wi.
GARY WEIRICH
11-14-2001 12:55:10
 Re: Re: MF 200 DOZER TRACK in reply to marlowe, 11-14-2001 12:39:57
Is there someway I could get a photo or more info?
