Massey Ferguson
Ken
11-08-2001 07:11:14
Need help identifying a Massey Ferguson tractor. It looks just like a 135, 150,165 etc, however, it is the size of a TO-20. Anybody know what it could be?
Gordon-Tn
11-17-2001 20:41:09
 Re: Massey Ferguson in reply to Ken, 11-08-2001 07:11:14
the s# on the MF-35 is under the stering wheel just above the stering rod on a rivited on plate The tractor you are talking about could be A I. M.T they are made over seas but I don,t know where
Gordon
Ken
11-19-2001 04:34:06
 Re: Re: Massey Ferguson in reply to Gordon-Tn, 11-17-2001 20:41:09
Thanks Gordon,
The S# plate on this tractor is on the engine, on the left side. It is a 4 cyl gas engine, with a high low and three forward gears and reverse. It stands about 44" high at the hood. The serial number is either Z134 or 756580. Both sets of numbers were on the plate. The first was on the left side of the plate, the second on the right. The plate was so worn that I could not read anything else.
Ken
william McBroom
11-12-2001 15:33:46
could anyone tell me where the seriel number is on a massey ferguson 35. This tractor is I beleive a 1957 35x it is a british one .
Thanks William McBroom
George From Ontario
11-09-2001 05:00:03
Dear Ken :
It could be a Massey Ferguson 25 or 130 made in France . These replaced the French Pony Tractors .
They looked like a MF 35 only smaller .
Hope this helps !
George
Alan
11-09-2001 07:11:34
 Re: Re: Massey Ferguson in reply to George From Ontario, 11-09-2001 05:00:03
We have a 135 Massey Ferguson, 1965. This was the first new style 135, with headlights on the fenders. It has a 4 cyl gas engine, 3 gears L and 3 gears H, plus 2 reverse. If yours has the four cyl engine it could be the same, as later ones had a 3 cyl engine gas.
Good luck,
Alan
Ken
11-09-2001 13:30:08
 Re: Re: Re: Massey Ferguson in reply to Alan, 11-09-2001 07:11:34
Alan,
This one looks just like your 135. Your 135's hood comes up to your chin or so, right? This one is more on the size of a Ford 8N. Its hood height is about belly height. Thanks for your help.
smokey
11-08-2001 21:21:57
What motor does it have and how many gears?
Ken
11-09-2001 04:56:27
 Re: Re: Massey Ferguson in reply to smokey, 11-08-2001 21:21:57
I really did not look. I did notice that it had a high/low shifter and a gear shifter. I will assume 6 gears. I knew to look for the number on the side of the hood but it was not there. I guess it would have been smart to look at the serial number on the motor and used that to look up the model number. I am trying to decide if I will offer to buy this tractor from this person or not. It clearly appears to have been worked on. The motor has been painted as well as the rest of the tractor. It also has a 4' bush hog attached but the lady said the tractor does not run. I expect that it is a minor problem to get it running.
Hal
11-11-2001 14:28:42
 Re: Re: Re: Massey Ferguson in reply to Ken, 11-09-2001 04:56:27
It could still be a 135, but might be a low-profile model. Look at the spindles on the front axle, they may be shorter than on a regular 135 and it may have small diameter wheels on the back. Also, I believe a few 135s were made high clearance with 38" tires on the back; maybe that is what you were comparing it to. I don't think a conventional utility 135 with 28" rear tires would come up to the average person's chin.
