Stalling and Stalling HELP!!!!!!
massey135'er
11-06-2001 12:50:24
My 135 gas massey is starting to stall like rock. Ill let it idle for 2 minutes...Stalls...Ill let it idle for 1 minute....stalls...Ill get her going a little bit...Bam...stalls...I have no idea what is going on, so if someone could give me some advicee i would greatly appreciate it...Lets just say...It wont stop stalling...Thanks alot S.G.
Tyler(WA)
11-07-2001 06:53:10
 Re: Stalling and Stalling HELP!!!!!! in reply to massey135'er, 11-06-2001 12:50:24
My guess is right along with the rest and I'd check out your fuel delivery first.
Next, I'd check to make sure your governor is working properly.
Then, look at ignition with primary attention to coil and plugs.
After that, you should give up all hope and just drop off that rotten old 135 at my place. ;-)
Be sure to let us know what you find.
smokey
11-06-2001 23:42:44
Check fuel filter. Don't know about petrol but diesel has mesh cone filter on tank tap and a very fine mesh filter above the filter bowl.
Big Dean
11-06-2001 17:27:55
I suspect your tractor is starving for gas either the line has a restriction in it or the screen on the elbow where the line hooks to the carburetor or the valve coming out of the tank are plugged. If it is the three cylinder Perkins it could be the little solenoid on the bottom of the carburetor. It could also be a bad ignition coil.
d land
11-06-2001 17:04:57
Check the Ford forum about a 641 workmaster with similar problem (641 workmaster dies periodically)
Some of the suggestions there might help.
