MF 300 Combine
know anything?
Faber
11-06-2001 05:26:08
Hey folks:
Does anyone know anything about a Massey Ferguson Model 300 combine? I know this is a tractor discussion, but I'm getting desperate. I've got a line on one in mint condition with a Chrysler V6 gas engine, and I think it would be a good size for a small (say 20 acres) corn stand.
Thanks
Faber
Texas
M Kimmel
07-11-2003 16:20:41
 Re: MF 300 Combine - know anything? in reply to Faber, 11-06-2001 05:26:08
Would anyone be able to tel me the different grain settings for this machine? I just bought one that is set up for oats but I don't have the book and I need to take off my barley.
Ricky Appling
10-05-2002 17:22:44
It would be the perfect combine for you because it is small and has enough power to shell corn but really I think the best thing the little combines are for is to thresh fescue seed but The 300 will thresh or combine wheat, soybeans, and corn, and theres not really a difference in a gas or a diesel burner except a diesel will out last a gas burner. Well good luck in making your decision
Ricky Appling
10-05-2002 17:22:04
Ricky Appling
10-05-2002 17:20:23
It would be the perfect combine for you because it is small and has enough power to sell corn but really I think the best thing the little combines are for is to thresh fescue seed but The 300 will thresh or combine wheat, soybeans, and corn. Well good luck in makind your decision
Mike
11-08-2001 02:36:15
Faber,
We also had a 300 gas in early days of farming. We found this machine to be a good runner. Had very little problems with it. Only problem I remember was replacing bearings for the variable speed drive pulley. The machine performed well. Hope this helps.
Mike
jim
11-06-2001 17:24:26
I purchased a 1963 300 in 1971 and ran it till 1982 while running 300 acres of mixed small grain (oats,barley and wheat) That machine also had a scour-klean on it and gave a good clean sample. No major problems and traded it for a J.D.3300 diesel with a cab (basically the same size machine). Incidently , those machines were made here in Ontario at Massey's Brantford plant which was opened in 1962-63 and closed in the early 1980's.
Neil
07-24-2002 19:54:27
 Re: Re: MF 300 Combine - know anything? in reply to jim, 11-06-2001 17:24:26
Hi
I own a Massey 300 combine. I bought it in the summer of 2002 at a local dealership. It has a v6 225 Chrysler gas engine. It runs real good. The combine itself is in decent shape and seems to operate. It is a 1965 model without a cab. They also offered a 4 cylinder diesel model. These are very small combines with 30 inch long cylinder. I bought mine to restore it in upcoming years if you would like to know certain things about it email me Because I can look it up in my manual and tell you.
[email protected]
Thanks
