Massey Harris plow ???
farmer
11-02-2001 12:46:54
If I didn't screw up the link it shows 3 plows I have acquired recently. I have reason to think plow #2 is maybe a Massey Harris. Can anybody tell by looking? Plows #1 and #3 are IHC.
BlueLite
11-13-2001 09:23:45
 Re: Massey Harris plow ??? in reply to farmer, 11-02-2001 12:46:54
Plow 1-3 is a #28, have one myself. I don't have a top MH stamp but #28 is barely visible
in white paint. Your plow has been painted red
but the original color is closer to a plane dark green, not JD green.
The moulboards are #23 boards on mine. The numbers painted on the underside of the boards and
again barely visible. They also made them in steel wheels. My rims are rusted bad and won't be able to remove the tires in fact, as the rim will
probably fall apart. Tires are 6X16 I think. Going to weld on new rims when that time comes.
I heard it was the best plow available and even to this day will give a better and more even furrow than a 3PH plow with less load on the tractor. When I try it out next year, I'm curious to see how rubber wheels will perform and I wonder if sliding will occur.
Tom
11-07-2001 12:20:42
If it is a Massey Harris plow, Massey Harris will be stamped on the top of the main beams. It looks like a Massey Harris #28 plow.
