Brake shoes
geb
11-02-2001 07:08:53
Can anyone tell me where to get brake shoes for a M-H 33? Thanx in advance!
Gordon-Tn
11-17-2001 21:27:00
 Re: Brake shoes in reply to geb, 11-02-2001 07:08:53
check with the local parts store,see if they will send your shoes to get them relined bonded on with glue,I got that done to mine and works fine
Good luck Gordon
BlueLite
11-13-2001 09:34:21
I have a 30 but should be similar. You may not find the shoes, but MF should be able to get
you the shoe linings with the rivets. You then
just grind off the rivets and re-rivet the new ones back on. If it's the band type brakes you have, you should still be able to get them from
MF.
A tip when your done and ready to put thinks back together. If the housing forms a natural catch basin for trans oil from seals that leak,
drill a 3/8in hole at the bottom of the housing
to let out the oil and prevent it from getting all
over the brake parts. It's easier to tell if your seals are gone too. The housing is only 1/2in or so thick at that point and won't cause any structural problems.
frank
11-02-2001 16:49:44
shoes? my 33 has round disc that look kind a like a clutch disc but smaller
