MF135 3PH stuck in up position
Steve
10-29-2001 06:39:11
I've got an MF135 Diesel that has developed a hydraulic problem on the 3-point hitch. Whenever I start the tractor, the hydraulics go into the "up" position, regardless of control lever position. Once it hits the raised position, it sounds like it's putting a load on the tractor. Any ideas on how to diagnose what's going on??
smokey
10-30-2001 17:27:40
 Re: MF135 3PH stuck in up position in reply to Steve, 10-29-2001 06:39:11
Try Link technicaltips/massey fergussen - about the best description this side of Big Dean.
Randy in Mo.
11-21-2001 22:30:23
 Re: Re: MF135 3PH stuck in up position in reply to smokey, 10-30-2001 17:27:40
I just fixed our 65 Massey and when I put the top
back on, I got the control lever that pushes the hydraulic valve lever inside the rear housing on wrong. When I started the tractor the hitch came up and stayed up. Took the top housing back off, adjusted the levers a little and put it back together and it worked fine. Hope this helps.
