Ferguson TO35
Two cylinders not firing
Larry Stewart
10-17-1998 17:31:30
Good spark coming to all four plugs. Compression on all cylinders approximately 120 lbs per sq inch. But the mystery is cylinders 3 and 4 are not functioning. I can remove these two plug wires with no difference in engine performance or starting. Any ideas, please?
Dennis
10-19-1998 11:36:51
 Re: Ferguson TO35 - Two cylinders not firing in reply to Larry Stewart, 10-17-1998 17:31:30
Had exactly the same problem with my to-30. Exactly the same symptoms. Found I had a broken valve spring. The valve wouldn't close and number three cylinder would compress over into number 4 really mesing up the compression check. It really stumped me until I pulled the valve cover. Ignition in either cylnder would fire over to the other which already had an open valve. Good luck !!
: Good spark coming to all four plugs. Compression on all cylinders approximately 120 lbs per sq inch. But the mystery is cylinders 3 and 4 are not functioning. I can remove these two plug wires with no difference in engine performance or starting. Any ideas, please?
Jack in NB
10-18-1998 03:23:44
Hi Larry -
Defective spark plugs? I've had them looking good, but shorting to ground inside the steel body. Try swapping 3 & 4 with 1 & 2.
Blown intake gasket? Test - with engine running, turn a propane or acetylene torch on a bit (not lit) and feed the gas along the intake manifold near #3 & 4 cyls. If it smooths out, that's the problem.
Harry
10-18-1998 05:03:51
 Re: Re: Ferguson TO35 - Two cylinders not firing in reply to Jack in NB, 10-18-1998 03:23:44
That is good advice, sounds like someone who has been there.
