Weak aux. hydralic pressure on Massey 180
Dean
10-14-2001 20:44:58
after mounting a front loader I discovered I had weak pressure coming from my aux. hydralics. My 3 point is strong and very responsive. I checked the pressure and I'm only getting a little over 300lbs. Am I having bypass problems or could it be something else?
Johnny
10-15-2001 16:31:24
 Re: weak aux. hydralic pressure on Massey 180 in reply to Dean, 10-14-2001 20:44:58
Two completely different hydraulic systems, you probably got a worn out pump, I replaced mine by last winter for about $700 by myself on a saturday. I have never had any luck trying to rebuild these pumps so I went with a new. Get a manual and do some research before you break into your tractor. On second thought, the aux. pump only works when the clutch is halfway out,makes for,in my opinion a crummy loader tractor, I would try to mount a front pump ahead of the engine if that is possible, also the aux. pump is incredibly slow. Johnny in E.Tx.
