When you turn it over with the cap off, do you get spark at the breaker gap? The gap should be set to .020 I think. I did a 12V conversion from the diagram on this board. I didn't change any ignition stuff at all and it works fine. The condenser is the same. I was scratching my head over the resistor thing as well, so I took a chance and I put a coil in that didn't need a resistor and just turned it over to see what would happen. It worked OK. Another thing too is at the bottom of the cap there is a spring loaded contact, is that OK. Thats all I can think of except maybe going over the coil and ignition circuit with a 12V light tester. Test to ground at various points to see where your getting current but stay away from the high voltage side of the coil. The old Motors auto repair manuals from the 1950's have basic ignition circuits and troubleshooting guides. Check out the public library. I was wondering, how did you get a new distributer as I've been searching all over and they tell me AutoLite is no longer available. Can you give me a part number and supplier? Thanks.
