44 Massey
geb
10-10-2001 07:03:36
I'm new to the Massey game and I'm looking some info. Is there a difference in the transmission and rear end in the 44, 444, and 44-6 tractors. Also will the engine out of a 55 bolt into a 44. Thanx in advace for your help.
Jake
10-11-2001 07:38:37
 Re: 44 Massey in reply to geb, 10-10-2001 07:03:36
Geb, I can help you out some. The 44 and the 444 are different rear ends. The 444 had a hi/low in for a total of 10 forward speeds. I believe that it also had provisions for a live pto that came out closer to the hitch. The 44 and the 44-6 use the same rear. However, I too have often wondered if they used different gears due to the rpm differences between the 4 and the 6. A 55 engine will 'bolt' into a 44 frame. There is one that comes to the local pulls around here every once in a while and does very well. Hope this helps...
