NEED HELP, just bought my first tractor. I have a few questions
Jason
10-08-2001 19:14:45
I just got my first tractor and its a Massey Ferguson MH-50. It is having alot of problems right now. The PTO only goes up about 3-6 inches. I checked the fluid by looking into the the place that you refill it at and cant see any in there..... how much does it hold and what do I put in there ? It says 90 engraved in the metal cap. Next problem: it starts up good and idles perfectly, the problem is when you put a load on it, it bogs down. It can hardly pull the bush hog. When I pull the throttle down it just bogs even more..... ..is it the carburator ? Please help. If you have AOL Instant Messanger and can answer me on that it would be great. My screen name is Y7WEB. Thanks for you help.
Steve
10-08-2001 21:44:56
 Re: NEED HELP, just bought my first tractor. I have a few questions in reply to Jason, 10-08-2001 19:14:45
Jason, I have a 1957 TO-35. When I was gett'n use to it I noticed that you can move the set bolt for both the PTO lfit and the "draft". When I had the draft handles in the max up position (pulled towards rear) the lift was substancially higher. Im not sure if your controls are simular. As for the bogg"n down, that could be as simple as clogged lines, crap in the tank, or bad /filth gas,etc etc....How long has the bad boy been sitt"n???? Start w/ the simple low cost items first. Its a way of learn'n your tractor anyway. Here is a site that helped me out alot Jason. Gave me info on fluid levels, amounts, timming, gap sett"n, ALL kinds of vital info.... Hey Good luck Bud & ENJOY!!!!! !! (www.geocities.com/MotorCity/Downs/9828/fergy_02)
