MF-40 AD4-203 Diesel: belt replacement
Ralph Walton
10-08-2001 12:36:07
My aux. (loader) hydraulic pump drive shaft prevents me from just slipping the new belt over the bottom pulley. It appears from the parts manual that the shaft is splined into the adaptor on the bottom pulley, but it looks like I'll have to drain the Hyd. oil and remove hoses in order to slide the pump and shaft forward to allow the belt to pass.
Any other brilliant suggestions?
Ralph Walton
10-08-2001 19:10:46
 Re: MF-40 AD4-203 Diesel: belt replacement in reply to Ralph Walton, 10-08-2001 12:36:07
Hey! There was a note in the archives about a MF201 workbull and a suggestion to loosen off both the Hyd. pump and the adaptor plate on the front of the crank... IT WORKED! The belt just passes behind the adaptor and bingo, job done.
