TO-30 OR TO-20 WHICH TRACTOR DO I HAVE
RW
10-14-1998 16:56:37
I recently purchased a tractor and was told it was a to-30. However after doing some research I have become somewhat confused. The serial # is 43851 which doesn't seem to correspond with the #'s for a to-30. Also on the side of the engine it says Z120A600. Stamped on the steering rod on the front it says TO-3130. The tractor runs rough but has potential. It has no dents and the grill is in excellent condition. I was thinking about buying an engine rebuild kit but I would like to know what I have.
brandt
10-24-1998 08:05:47
 Re: TO-30 OR TO-20 WHICH TRACTOR DO I HAVE in reply to RW, 10-14-1998 16:56:37
: I recently purchased a tractor and was told it was a to-30. However after doing some research I have become somewhat confused. The serial # is 43851 which doesn't seem to correspond with the #'s for a to-30. Also on the side of the engine it says Z120A600. Stamped on the steering rod on the front it says TO-3130. The tractor runs rough but has potential. It has no dents and the grill is in excellent condition. I was thinking about buying an engine rebuild kit but I would like to know what I have.
I always told them apart by the oil filter. The 30 has
an external filter and the 20 has one inside the oil pan.
You access it by removing a large circular plate on the
bottom of the oil pan.
M. Smith
10-14-1998 17:38:01
If it has the Z120 engine it should be a TO20.
