Oil coming out of MF165 exhaust
Ed
10-02-2001 02:36:34
I have a 1969 MF165, and it has recently started to dribble oil out of the top of the exhaust pipe. She has also started to chuck out grey smoke. What is this a sign of? oil getting past the valves? new set of rings needed?
Michael
10-05-2001 00:39:30
 Re: Oil coming out of MF165 exhaust in reply to Ed, 10-02-2001 02:36:34
Check first the level in the crankcase.
I had the same problem on my Ford 5000.
If you have too much oil you can get this problem.
Jon
10-05-2001 04:21:55
 Re: Re: Oil coming out of MF165 exhaust in reply to Michael, 10-05-2001 00:39:30
Could also be worn valve stems or valve stem seals if fitted (unlikely on perkins), head gasket failiure, or broken piston rings.
