What type of oil (lube) do I put in TO 30 rear end
David C.
10-13-1998 19:13:47
I have found that I have a TO 30 (don,t know year yet) and I need to know what kind of lube goes in rear end Thank you David C.
Bill Brox
10-14-1998 09:58:12
 Re: What type of oil (lube) do I put in TO 30 rear end in reply to David C., 10-13-1998 19:13:47
Hi David,
If you like, you can use an engine oil, 15W-40 the same oil that will be recommended on your engine in the summertime.
My local MF dealer recommends this oil.
Easy to have only one oil to deal with.
Bill
: I have found that I have a TO 30 (don,t know year yet) and I need to know what kind of lube goes in rear end Thank you David C.
David C.
10-15-1998 05:19:59
 Re: Re: What type of oil (lube) do I put in TO 30 rear end in reply to Bill Brox, 10-14-1998 09:58:12
Bill, (or any one else)
I have found a local dealer who told me the original oil in the rear end (3 point hitch and trans included) was 90 weight mineral oil. They also said 90 weight lube had addetives that would damage the rear end.
Can any one verify this? Thank you David C.
Bill Brox
10-15-1998 07:32:22
 Re: Re: Re: What type of oil (lube) do I put in TO 30 rear end in reply to David C., 10-15-1998 05:19:59
Original gear oil for Ferguson is gear oil 90 weight. But engine oil 15W-40 has the same weight as the 90 gear oil, or very close. They even recommend the engine oil.
If you want to use 90 weight gear oil you need to be absolutely sure it is NOT an EP or HD oil. EP is Extreme Pressure, and HD is HYPOID oil.
EP and HD additives will damage your rear end.
This is some of the reason I always recommend using engine oil 15W-40 from the same bottle you use on the engine. With engine oil you can't do any mistakes.
15W-40 or 15W-50, doesn't matter.
Hope this helps.
Bill
: Bill, (or any one else)
: I have found a local dealer who told me the original oil in the rear end (3 point hitch and trans included) was 90 weight mineral oil. They also said 90 weight lube had addetives that would damage the rear end.
: Can any one verify this?
: Thank you David C.
DB
10-17-1998 18:47:07
 Re: Re: Re: Re: What type of oil (lube) do I put in TO 30 rear end in reply to Bill Brox, 10-15-1998 07:32:22
: Original gear oil for Ferguson is gear oil 90 weight. But engine oil 15W-40 has the same weight as the 90 gear oil, or very close. They even recommend the engine oil.
: If you want to use 90 weight gear oil you need to be absolutely sure it is NOT an EP or HD oil. EP is Extreme Pressure, and HD is HYPOID oil.
: EP and HD additives will damage your rear end.
: This is some of the reason I always recommend using engine oil 15W-40 from the same bottle you use on the engine. With engine oil you can't do any mistakes.
: 15W-40 or 15W-50, doesn't matter.
: Hope this helps.
: Bill
: : Bill, (or any one else)
: : I have found a local dealer who told me the original oil in the rear end (3 point hitch and trans included) was 90 weight mineral oil. They also said 90 weight lube had addetives that would damage the rear end.
: : Can any one verify this?
: : Thank you David C.
I have a 1953 TO30 and about 20 years ago i had to change the pto coupler to the standard size(1 3/8) and at that time i changed the oil to an EP 90 weight oil and have not ahad a lick of trouble out of theis unit for the last 20 years.
Bill Brox
10-18-1998 12:19:37
 Re: Re: Re: Re: Re: What type of oil (lube) do I put in TO 30 rear end in reply to DB, 10-17-1998 18:47:07
The manual says: NO EP or HD oil.... never tried the "wrong" oil... so I have no idea what can and won't happen. Just tried to stay out of trouble.
Bill
: : : Original gear oil for Ferguson is gear oil 90 weight. But engine oil 15W-40 has the same weight as the 90 gear oil, or very close. They even recommend the engine oil.
: : If you want to use 90 weight gear oil you need to be absolutely sure it is NOT an EP or HD oil. EP is Extreme Pressure, and HD is HYPOID oil.
: : EP and HD additives will damage your rear end.
: : This is some of the reason I always recommend using engine oil 15W-40 from the same bottle you use on the engine. With engine oil you can't do any mistakes.
: : 15W-40 or 15W-50, doesn't matter.
: : Hope this helps.
: : Bill
: : : Bill, (or any one else)
: : : I have found a local dealer who told me the original oil in the rear end (3 point hitch and trans included) was 90 weight mineral oil. They also said 90 weight lube had addetives that would damage the rear end.
: : : Can any one verify this?
: : : Thank you David C.
: I have a 1953 TO30 and about 20 years ago i had to change the pto coupler to the standard size(1 3/8) and at that time i changed the oil to an EP 90 weight oil and have not ahad a lick of trouble out of theis unit for the last 20 years.
