Massey Furgeson 50 Loader/aux pump/valve assembly
Mr Hawk
10-13-1998 15:09:13
I recently installed a Furgeson Loader on my 50 tractor. But had to temporarily use an aux. pump off the pto shaft. I really need to switch it to a front hub pump. I've found the pump, and drive shaft, but still need the pulley/hub with internal spline to fit it all together. Any help will be appreciated. Also I am looking for a set of double acting cylinders for the lift, and any information about the convertion of the factory, non double acting valve body that I now have. Thanks to who ever can help.
Hawgee
10-14-1998 06:58:59
 Re: Massey Furgeson 50 Loader/aux pump/valve assembly in reply to Mr Hawk, 10-13-1998 15:09:13
: I recently installed a Furgeson Loader on my 50 tractor. But had to temporarily use an aux. pump off the pto shaft. I really need to switch it to a front hub pump. I've found the pump, and drive shaft, but still need the pulley/hub with internal spline to fit it all together. Any help will be appreciated. Also I am looking for a set of double acting cylinders for the lift, and any information about the convertion of the factory, non double acting valve body that I now have. Thanks to who ever can help.
Go here and request the catalog. As good as CT and some others. Have used them to do the same on Davis loader for MF35U.
Link
More cylinders at
http://www.baileynet.com/
