MF135-fuel gauge and sending unit wiring
Tim (TX)
09-21-2001 15:39:58
I have a MF135 AD3-152 diesel (1965). Fuel gauge was'nt working so I ordered a new gauge and sending unit. I have a wiring diagram but cant seem to figure it out. The gauge has 3 terminals: 1 ground, 1 labeled B and 1 labeled T.
I assumed the B was battery and T was Tank..?
The sending unit has 1 terminal and then a ground wire that attaches under any one of the 5-6 screws that hold it to the tank. Still does'nt work. Its a 12volt. Any suggestions would be greatly appreciated. Thanks.
Bill
09-23-2001 20:01:45
 Re: MF135-fuel gauge and sending unit wiring in reply to Tim (TX), 09-21-2001 15:39:58
Hi, The alternator or voltage regular not working can cuase the fuel guage not to work. If you replace the mechanical voltage regular with a electronic one the fuel guage will not work, been there done that. Bill
Bill
09-23-2001 20:10:21
 Re: Re: MF135-fuel gauge and sending unit wiring in reply to Bill, 09-23-2001 20:01:45
Hi again, This is assuming you have an alternator ( Massey calls it an AC gererator). If you have a operators guide there is a wiring diagram in it. Bill
Tim (TX)
09-24-2001 18:26:58
 Re: Re: Re: MF135-fuel gauge and sending unit wiring in reply to Bill, 09-23-2001 20:10:21
Thanks a lot guys. The wiring under the dash was really in a mess. I used a diagram that Big Dean drew up that helped me locate the oil pressure switch (I had a wiring diagram from the manual and one that Paul pointed me to, but was unable to figure out what or where the oil pressure switch was!). I will keep that in mind about the voltage regulator, Bill. I ran a new wire to the oil pressure switch and my fuel gauge now works.
Thanks again,
Tim
Sander
05-13-2003 06:31:17
 Re: Re: Re: Re: MF135-fuel gauge and sending unit wiring in reply to Tim (TX), 09-24-2001 18:26:58
I'm having the same trouble. Where can i find that oil pressure switch? It's called oil pressure sending unit in my diagram, they just don't tell me where it is
Paul in NM
09-21-2001 20:19:31
Tim - go to this site and look at the diagram on the left end of the bottom row. Hopefully this will help.
Paul Nelson
