Starts, tries to die, runs fine???
hotFusion
09-21-2001 01:59:08
I have an MF 65 that has (in about the last month) started trying to die when I first start it. I will start it, and in about 20 to 30 seconds it will start trying to die. If I cut the throttle all the way it won't die and will idle, then I have to slowly increase throttle untill it starts to choke again, then I cut it back, I have to do this for about a minute untill it seems to get over the hump and then I can go back to full throttle and use the tractor normally from that point on. It only does it from cold starts, I never had this problem on a warm start, any ideas. My first thought is that something must be clogged but that is just my guess. I'm stumped.
D.G.
09-30-2001 23:48:12
 Re: Starts, tries to die, runs fine??? in reply to hotFusion, 09-21-2001 01:59:08
FUEL SYSTEM HAS AIR IN IT. REPLACE FILTER/S & ALL RUBBER O RINGS & REPRIME THE FUEL SYSTEM MAKING SURE YOU CRACK OPEN & CLOSE ALL INJECTOR/FUEL PIPE NUTS WHILST ENGINE IS RUNNING.
hotFusion
10-01-2001 03:40:00
 Re: Re: Starts, tries to die, runs fine??? in reply to D.G., 09-30-2001 23:48:12
Is this a serious problem? Should I be overly concerned?
