STARTING TO35
ROBERT L. MANNI
09-17-2001 12:04:02
OK, ALL YOU TRACTOR GUYS. I HAVE A QUESTION THAT I COULD NOT FIND AN ANSWER TO ON THIS WEB SITE. I JUST RESENTLY PUCHASED A FERGUSON TO35 GAS TRACTOR. IT WAS RUNNING GOOD WHEN IT WAS PUT UNDER A SHED AND HAS NOT BEEN USED FOR ABOUT 3 YEARS. I WOULD LIKE TO START THIS TRACTOR, BUT DO NOT WANT TO DAMAGE ANY THING. DO NOT WANT TO BREAK DOWN THE ENGINE IF POSSIBLE. NEED ALL YOUR YEARS OF KNOWLEDGE AND EXPERTISE. THANKS.
Bob in CA
09-17-2001 20:23:18
 Re: STARTING TO35 in reply to ROBERT L. MANNI, 09-17-2001 12:04:02
Robert,
I have never had any trouble after three years of storage but it may depend on your climate. In the dry climate in the California foothills I have never done anything special after long term storage. I f live in a climate with more moistur you may have require a little more finesse. I would strart by removing the spark plugs and squirting a little lubrication in the cylinders. If the engine will rotate by hand or slight wrench pressure, I would use some light top cylinder oil like Marvel Mystery oil or 3in1. If the cylinders seem a little stiff, I would use some Liquid Wrench and rotate the engine with a wrench several rotations. If the engine then rotates free I wouldn't hesistate to start the engine. I would warm up the engine for about ten minutes and then drain the old oil out. You may also want to drain the fuel from the tank and carb and flush. After three years the fuel may be suspect. Open the fuel cap and smell it. If it smells alright it may be OK to fill the tank and dilute the old gas. Good Luck.
ROBERT L. MANNI
09-18-2001 06:25:31
 Re: Re: STARTING TO35 in reply to Bob in CA, 09-17-2001 20:23:18
THANKS BOB,
I LIVE IN PANAMA CITY, FLORIDA. LOTS OF MOISTURE
HERE. WILL TAKE YOUR ADVICE. I'LL LET YOU KNOW THE OUTCOME.
