MF135 Hydraulic oil filter
Graham Vayro
09-17-2001 05:16:41
Is it possible to remove and or clean the hydraulic filter through the PTO selector lever cover on the left side of the tractor below the seat? I can see the filter in there but cannot get it out. Manual does not answer this question.
Tim Hubbard
09-19-2001 19:33:02
 Re: MF135 Hydraulic oil filter in reply to Graham Vayro, 09-17-2001 05:16:41
That's the right access plate. From the manual: remove the PTO control lever assembly. Reach in and unscrew the wing bolt (yours may be a bit tuff if its been in there awhile) that holds the filter assembly in place. Remove the entire filter assembly by lifting up. BE SURE TO REMOVE THE ASSEMBLY AS ONE UNIT. If the lower metal sump base is allowed to drop off, the dirt and sludge will fall back into the trans...not a good thing. Take it out, clean or replace it. Put it back in, making sure the gasket is in place. Also, when re-installing the control lever assembly, make sure the shifting fork is in place.
Tyler(WA)
09-18-2001 08:56:27
I replaced mine and I think that's the plate I removed to access it. It came out easy enough and my owner's manual gave good instructions on how to do it.
That was over a year ago and not near my manual right now.
