Massey harris
george hillsgro
09-16-2001 13:24:06
will a massey 44 special trans with high-low range fit a masset 44-6 tractor ?
Michael
09-16-2001 14:40:18
 Re: massey harris in reply to george hillsgrove, 09-16-2001 13:24:06
George,
44 Specials were all 5 speeds, from October '52
through the 1955 production end. The 333/444
series were 5 with a high/low range. Trying the
interchange, I know a 444 U-frame will bolt to a
44 Special transmission case. But the U-frame on
the Special was heavier than regular 44 models. If you had a Special, measuring the frame near the
battery box, is about 1 1/4" thick, a 44-6 about
7/8" thick. The WFE pan brace from a 44 is not
as wide as the Special brace. I would do careful
measuring on those U-frame bolts, but have some
doubts a 44-6 engine & U-frame would work with a ten speed, obviously from a 333/444 series. They
may look the same, but wasting a day of sweat labor to prove no, is not fun, plus any parts you
invest in this project. Perhaps someone has done
this challenge, watch the replies for consensus.
That F226 was a prankster, at a slow idle, a hundred feet away, you had to guess if it was actually still running with it's stock Nelson
muffler. Good luck.
